» WenMac 049 - Glow Plug & Head Gasket replacements?by Ken Cook Today at 3:17 pm
» audio-tach anyone?
by roddie Today at 2:58 pm
by roddie Today at 2:54 pm
by rsv1cox Today at 2:43 pm
by 1/2A Nut Today at 1:58 pm
by Admin Today at 1:11 pm
by rsv1cox Today at 10:26 am
by rsv1cox Today at 7:32 am
SOLd OUT Cox .010 Carburetors with wrench
Last edited by sosam117 on Fri May 10, 2024 6:29 pm; edited 5 times in total (Reason for editing : Sold out)
sosam117- Diamond Member
Re: SOLd OUT Cox .010 Carburetors with wrench
One sold to Balogh and off to Hungary it goes!
Thanks, Andras
Only two left.
Thanks, Andras
Only two left.
Sent a PM for 1
Will PP now, thank you Mike!
1/2A Nut wrote:Sent a PM for 1
O.K 1/2A nut (Brad)
I've added it to the other part you purchased.
Thanks again!
Now only one left for sale!
Mike do you have a running vid on this one?
Working on two more Cox .010 carburetors with wrenches.
The blue dot is that I know it is the .010 carb body.
The others have different color dots as well. (Green and Red)
You can take it off if you like?
Yes,
I am working on getting some .10 mufflers for them.
Those little buggers are harder to make parts for than the larger .049 parts.
I can see why you would like to gt an .010 muffler ---- to remove that piece of tin/aluminum.
I'm working on it and will let you know when they are up to my quality standards.
Thanks 1/2A Nut
Thanks 1/2A Nut
How about sosam117, great job creating the air valves. I'm also planning to do something similar for my engines, a matter of personal challenge.
The air valves placed on the rotary valve of the crankshaft, for lower rpm, often require pressurization. Therefore I believe that the complete system will work very well with an exhaust chamber with a pressurization peak, plus the air valve placed on the rotary valve of the crankshaft.
What do you think?
What do you think?
MauricioB- Top Poster
Friend AndrĂ¡s, I congratulate you on your new acquisition...I'm glad that it works reliably.
I would like to take this opportunity to tell you as a precautionary measure something that has happened to me with my model airplanes. Some time ago I put covers for acceleration controls, it turns out that over time, the post-combustion oil begins to get between the steel cable and the cover, making the movement very heavy, it even sticks due to the oil. From that experience, I no longer put a cover on the throttle control steel cable, I only send the steel cable only passing through the wood of the fuselage. This way I never had problems again.
I indicate in your photo with a yellow arrow.
Please take my indication as a suggestion.
Excellent Brad!...you will surely do some rehearsals to share!!
Congratulations on your purchase friend!
Thank you Mauricio on your note about the pushrod sleeve. Yes, this may easily get the rod stuck in drying castor, so must be kept clean. I use the sleeve to strengthen the pushrod so that it will not bend and buckle when pushed by the servo which is in the middle of fuselage length i.e. the rod is rather long so buckles eaily.
» Sold out Cox .020 Carburetors for sale
» Sold out Cox .049 carburetors for sale
» RC Carburetor for Cox Pee Wee .020 / .049 / Tee Dee .010 - .020 - .049/.050/.051
» SOLD! Blackhawk Models**SOLD**
